Go Back   Impala SS Forum > 91-96 Impala/B-body > PCM Programming/Engine Management
Old 11-05-2009, 01:00 PM
MrBuick (Magnum)'s Avatar
MrBuick (Magnum) MrBuick (Magnum) is offline
MrBuick (Magnum) is an unknown quantity at this point
Send a message via AIM to MrBuick (Magnum)
Default "PCM EEB" to a "PCM EE", PCM?
So I finally got my tuner CATS to work, and started reading all the PCM's I have around. Now one of them, that I need to make a copy of, for another car, so I can do the OBD-I conversion... is a PCM EEB. So basically, the file that I have, that I want to copy. Is a PCM_EEB, where as the PCM I want to put it into is a PCM_EE. Is this going to cause any problems? I'm really not sure what the Rare Rivision PCM_EEB, as far as what trully is the difference.
~Cory Magner "My name is Cory, and I'm an addict."
95 DCM Buick RMS 14.21 at 91.79 "Jesus", Motor Swap at 85k
95 DCM Buick RMS 13.52 at 99.33 Buffman's Car, Fried Ring at 180k
RAISS, Tri-Y's, Pypes X pipe, Spintech Prostreets, 3000 Edge, 3.73's, Eaton Posi. GMPP 845 cammed engine coming.... eventually...
Plus 6 other LT1 B-body's... And currently looking for more. Is there Rehab for this Drug?
Old 11-05-2009, 01:12 PM
Buffman's Avatar
Buffman Buffman is offline
Moderator
Buffman is an unknown quantity at this point
Send a message via AIM to Buffman
Is the actual bin file an EEB or is the PCM listed as EEB? Figure out what the actual BIN file is. If this is not a stock tune, more than likely its in EE forumat.
Matt Hoffman
Exhaust Video Burnout!! New Quick Video!
ET: 13.5272 @99.33mph 1.82 60'
^^ Gone 7/12/09, but not forgotten
Old 11-05-2009, 01:33 PM
ProTools4's Avatar
ProTools4 ProTools4 is offline
ProTools4 is an unknown quantity at this point
Send a message via AIM to ProTools4
your injector size will come up some wacky size
if you open with the wrong calibration
I always check for that.
NotoriouSS Tad <-- custom Tri-Y post!!!!stay tuned!
96' ImpalaSS - Johhny 5 - 7.9 @ 89.07 1.734 and re-DYNO SOON!!!
67' El Camino - Rosie - 7.9 @ 86.5 1.77 60' on a street tire NA
Old 11-05-2009, 03:47 PM
Rocko350's Avatar
Rocko350 Rocko350 is offline
Rocko350 is an unknown quantity at this point
You can flash an EE bin onto an originally equipped EEB calibration and vise versa. Be very selective about which tables you cut an paste between the different formats, the displayed values in both variations are different when viewed with each others definition file.
Originally Posted by Erik View Post
My first advice to you is to edit that and call me from a payphone.
Old 11-05-2009, 09:54 PM
Yea, I was reading the tuner basics, and saw that. It had some really jacked up values for a few tings when you open a EEB, in the EE def file.
Old 11-06-2009, 11:22 PM
sbs's Avatar
sbs sbs is offline
sbs
No such thing as an $EE or $EEb PCM. Same hardware.
Presumably this is going into a 96 car. $EEb code won't know how to control your PWM lockup.
Old 11-10-2009, 07:09 PM
RamAirRocket's Avatar
RamAirRocket RamAirRocket is offline
Location: Rockford IL, just below the cheddar curtain....
RamAirRocket is an unknown quantity at this point
Send a message via Yahoo to RamAirRocket
There are 2 types of memories out there, top boot loader and bottom boot loader. Intel uses top, and Hynix and Toshiba usually use bottom.
So yes, can be "same" hardware to a point, but due to manufacturing volume the supplier had to have a second source on the memories.
Personally I haven't seen a bottom boot loader PCM, all have been top (intel) that I have and have seen.
Basically if the bootloader takes up 1K of space, then it would have to be taken account of, and everything shifted 1K up or down in the definition file.
Yes, they DO exist, just relatively rare.
94 Cadillac Fleetwood Brougham V4P
99 Chevrolet Suburban K2500 454
80 Turbo Trans AM, pure Pontiac 400
Resurfacing Wisconsin highways 2 long black strips at a time...
LS6 Injectors, Factory 3.42's (temp 9C1 3.08's and a G80 posi....), 9C1 air deflectors, 9C1 wipers, 9C1 body bushings, "YH" Caprice Wagon springs, ZQ8 Bumpstops, Wingspan Mod, polyurethane end links, PG260 starter, factory RPO V4P, FE2, V08, GU6...
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
