Go Back   Impala SS Forum > 91-96 Impala/B-body > Engine Problems/Maintenance
  #21
Old 11-06-2009, 09:05 PM
kpeters59 kpeters59 is offline
kpeters59 is on a distinguished road
I flushed it AND changed the filter.
I'm not even sure if there was water in it.
That transmission was rebuilt at the first of the year.
How would water have gotten in? Isn't it under pressure inside there?
-KP
  #22
Old 11-06-2009, 10:58 PM
grandpas wagon grandpas wagon is online now
grandpas wagon
Originally Posted by Jim Rockford View Post
Did you flush the trans , or just drop the pan and change the filter and top off with 5 qts? If there was any water in the trans fluid, the trans is DONE , water in the fluid ruins the clutchplates, and if there wasn't any water and you had it flushed with a machine, its done also, NEVER flush a trans that has any large amount on miles on it.
This undocumented, unproven, old wifes tale about high miles and flushing has reared its ugly head again.
grandpas wagon
1994 RMW 62K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoRam Atlanta headlights.
  #23
Old 11-06-2009, 11:42 PM
bob441's Avatar
bob441 bob441 is offline
bob441
Default I would...
Pull the plugs out of the tranny and check for water before you take it to the transmission shop.if the water got up high enough to get in the breather tube (the only way to get in IMO)you would be having more troubles than it slipping ,that green plug is the main electronics plug
1996 Caprice leather G80 V92 driftwood metallic
(2)1994 Fleetwoods 1 is family car 1 is future sleeper
1994 wagon caddy taillights -sold it
1988 Trans Am AA8 Nothcback 5.7 TPI
  #24
Old 11-07-2009, 01:57 AM
Well...I took it to the nearest tranny shop that could do a power flush.
Now, I guess I need to take it to the guy who built the tranny. Hopefully it won't need a whole rebuild. It was expensive.
Is there anything I can put in it that might help mitigate problems?
This is a bigger disaster than I thought...
-KP
  #25
Old 11-07-2009, 12:41 PM
Default Barsleaks?
What about Barsleaks for the transmission? Could it be of any help?
-KP
  #26
Old 11-07-2009, 01:34 PM
Dustan Dustan is offline
Dustan
Send a message via AIM to Dustan
i would not add any kind of "additive" to the tranny...4l60E's can be pretty tempermental
1996 Impala SS DGGM- 20's, black interior, budget headers, 2500 stall in front of solid built 4L60E,CAI,PCMforLess tune, Sprint springs, Rustic Front end, Walbro 255, 20x8.5 U2-35's, knightshaded 91's, fresh painttt
1996 Impala SS DGGM (moms)- polished stockers, flows, charcoal carpet
1997 Mazda Miata- GIVEN to me, daily driver, intake, 15" Konigs
2006 Suzuki GSXR 750
Impala SS Owners Association of Hawaii (ISSOAH)
  #27
Old 11-08-2009, 01:09 AM
I took it for a bit of a test drive today. At first, it would immediately stall if I tried to idle in gear. Like I'd dumped a clutch. If I feathered the gas with no brake when I put it in gear, I could go. After about 1 mile, that stopped. When I made it to the feeder road, it ran pretty strong. After about a mile on the freeway, it started slipping really bad in 3rd and 4th. I drove about 2 miles to the next u-turn and noticed the stalling was back. By the time I got home, I wasn't sure how well the engine was running.
I put some anti-freeze in the fuel tank.
I guess I'll get it to the transmission shop Monday morning.
-KP
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
