Go Back   Impala SS Forum > 91-96 Impala/B-body > Drivetrain
Old 11-05-2009, 01:10 PM
Sshockr Sshockr is offline
Sshockr is an unknown quantity at this point
Default Transmission Cooler
Can I run just the stock external cooler and bypass the internal radiator cooler?
I'm sorting out some issues with possibly putting the drivetrain in a '63 C-10 spending as little as necessary. I have 2 external radiators I could gang together if more than 1 isn't enough. The truck doesn't tow. If I start to tow with it I'll re-visit this issue.
- Brian
'95 B4U T56 in Purple Pearl with a few add on's.
Still in Wichita.
Old 11-05-2009, 06:34 PM
Nevermind, google shows that this is probably a really bad idea. So I will have to figure out soome sort of radiator mod type deal. Hmmm... The cost column is getting larger. (Like Leon.)
Still in Wichita.
Old 11-06-2009, 07:23 AM
tbsimmons tbsimmons is offline
tbsimmons
Why not?
My car is like that right now.
Yes the radiator part will help it cool more because the amount of energy that can be taken out from the fluid to fluid, but it would still work fine.
Troy Simmons
FASST - ROD - ISSCA
CPT Full Manual 700R4
Big Stall Big Gear
Old 11-06-2009, 08:12 AM
Hmmm. For my side project my 2 big hurdles are cooling everything and fuel. If this is truely an acceptible solution for now I think I can make the rest of the cooling work by playing with the hoses for the rest.
Still in Wichita.
Old 11-06-2009, 11:13 AM
NO DUBS's Avatar
NO DUBS NO DUBS is offline
NO DUBS is on a distinguished road
Mine will be like that in 2 days.
Josh Chapin
94 SS- 355 LT4 W/lots of bolt ons
Old 11-06-2009, 03:01 PM
GuillaumeC's Avatar
GuillaumeC GuillaumeC is offline
GuillaumeC is an unknown quantity at this point
I have always run just the external cooler unless I drive it in winter, never had a problem.
I dont like the radiator trans cooler... if they fail, coolant gets in the transmission and thats never a good thing... and they do tend to fail more often than regular hoses to an external cooler.
Guillaume Charest
1995 DGGM Caprice B4U, 355ci twin turbo street car, 4200 lbs
2008: Stock heads, 846 cam+bolt-ons, N/A: 12.49 @ 110.8 60'=1.65 nitrous = 11.49 @ 117.1 60' = 1.54
2009: Twin turbo setup in progress, first time out = 11.49 @ 121.7 mph 60' = 1.80
Old 11-06-2009, 06:37 PM
I've failed the internal before. The mixture of water and trans fluid was one of the reason I now have a T-56. No external cooling. So it sounds like I should be ok with 1 stock trans cooler on a light then B-Body vehicle. Sweet. And thanks to google and the guy's who rockcrawl 5.0 powered bronco's I now have figured out how to run the efi with stock fuel truck tank and a fairly inexpensive fuel pump out of a F-150.
Still in Wichita.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
