you can pick up a good set of used full roller rockers for @ $150. i have no complaints with my 26915 beehives tho there are cheaper options. after you have all the other stuff. a 52mm throttle body will give you modest gains. then there is always the little blue buddy if you just want bang for the buck
1995 bolt-on RMW (thanks fred)
14.174/94.07 motor stock TB
14.056/95.32 motor 52mm TB
12.64/106 150 shot
9.377/152.69 '00 Hayabusa with 270lb rider
8.72/162 99 Hayabusa same fat rider
